  • 1.  Placing System Date (Current Date) in a Recurring Report Subject Field (7.6.1.2 SQL Server)
    Posted 03-15-2024 15:44
    Does anyone know of a way to place the system date or current date into the subject line of a recurring report?
    Example: Daily PM Work Order Generation Report - 3/15/24
    I've tried :&DATE: and :DATE and :SYSDATE with no luck.
    Stevie Holloway
    Tufts University
  • 2.  RE: Placing System Date (Current Date) in a Recurring Report Subject Field (7.6.1.2 SQL Server)
    Posted 03-15-2024 16:11
    Hi Stevie
    Look, These 3 option seem to work from a Communication template and they should work
    :DATE
    :TIME
    :DATETIME
    :date
    :time
    :datetime
    I hope so. Regards!
    Mfsi
  • 3.  RE: Placing System Date (Current Date) in a Recurring Report Subject Field (7.6.1.2 SQL Server)
    Posted 03-15-2024 21:04
    Hi Stevie - I hope you are doing well!
    I think that I would try the following, which should provide you the standard bind functionality that you are looking for in your Scheduled Report (for both Subject and Message) using :&DATE&, as an example:
    from psdi.mbo import SqlFormat
    def getResolvedField(m, field):
        sqlf = SqlFormat(m, m.getString(field))
        sqlf.setIgnoreUnresolved(True)
        return sqlf.resolveContent()
    def main():
        if interactive:
            return
        mbo.setValue("EMAILSUBJECT",  getResolvedField(mbo, "EMAILSUBJECT"))
        mbo.setValue("EMAILCOMMENTS", getResolvedField(mbo, "EMAILCOMMENTS"))
    main()
    I created this with an Object Launch Point, on Initialize Value against the REPORTSCHED Object.
    Good luck!
    Aaron Paroulek
    Maven Asset Management
  • 4.  RE: Placing System Date (Current Date) in a Recurring Report Subject Field (7.6.1.2 SQL Server)
    Posted 03-16-2024 10:26
    Hi Aaron,
    I'm doing well. Thank you. How are you?
    I try this out and report the result. Is this Jython or Python?
    Stevie Holloway
    Tufts University
  • 5.  RE: Placing System Date (Current Date) in a Recurring Report Subject Field (7.6.1.2 SQL Server)
    Posted 03-17-2024 07:21
    Hi Aaron,
    I took a chance and used Python, and your coding worked perfectly.
    Thanks so much.
    Stevie Holloway
    Tufts University
