Hi @John Bauer! I don't quite understand what you want to do. In your code you already include both launch points and determine what the script is going to do. What do you need to do? Add the 2 launch points?
In automation Scripts you need to "Create" Script with attribute Launch Point. Then you need to complete date, the most important is call the new launch point DESCRIPTION and JPDURATION (you need to repeat the process two times). In Script section, you need to set "Existing Script" and then you need to select your existing script that you want to add the launch point attribute.
If that is not what you need, let me know and I will be happy to help you.
