Hi Patricia,
Unchecking the Active checkbox on the Launch Point should be all you need to disable the script. If you get the error even when the script is disabled I would assume it's not a script issue.
You might check the ASSET2WO domain to ensure the Validation Where Clause isn't too restrictive when excluding your Assets based on Status.
