Can you provide some more detail such as
- Is this a new IFACETABLE or an existing one?
- Has a Maximo patch been applied recently?
You may want to try and recreate the IFACETABLE from External Systems as an initial debugging step. Make sure you select the backup option when you do this. If it has no issues creating the IFACE table then try re-running the Cron to see if that works. If the IFACE fails to create you likely will get a better error message that will hopefully point you in the right direction. Based on the error you provided there may be a lock on the table at the DB level.
Mike
