I'm using Maximo 7.6.1.2. When I query up a couple of Work Orders in the Work Order Tracking app, navigate to each one and modify the Duration field and hit save on each record, when I navigate back to the list tab, I see that the rows I changed/saved were modified because the app is making them italicized (see image).
I've created a custom Select Action (see "Calculate Estimated Duration (All)" Select Action in screenshot above) that launches an Automation Script that will recalculate all of the selected Work Orders' Duration values. When the script executes, it calls Save on the MboSet (I've also tried Save on the ResultsBean), it is saving the changes; however, it is not showing/marking any of the records as having been modified in the List tab. Does anybody know what AppInstance or ResultsBean or DataBean or other class method I would need to call from within the Automation Script to make it mark those rows which have been modified (like it does out of the box when I navigate to each row manually and modify/save)?
#Automationscript
Hi Jared,
Call the below
public void setListTableModified(boolean inChange) of DataBean class.Used in conjunction with public void setListTableRetain(boolean inRetain) method of same class.Try it and verify. check the JavaDocs if needed.
@Subhransu Sekhar Sahoo Unfortunately, trying to use DataBean.setListTableModified(True) did not help. I did confirm with getListTableRetain() that it was enabled.
