hello,
I'm trying to use the system() function from the os library to print out system data and I get the following error:
AttributeError: type object 'os' has no attribute 'system'.
I've tried using other functions of the same library and I get the same error, the only content I can access from the os library is os.name.
I've tried updating the os library from the library's directory but it didn't work.
I'm using Maximo version 7.6.1 with python 2.7.
Does anyone know how to fix this or get the system info with another way?
Thank you.
