Thanks Prashant for your reply.
This error is resolved and could connect to mssql DB by using the below driver instead of "mxe.db.driver=com.inet.tds.TdsDriver" in maximo.properties file.
com.microsoft.sqlserver.jdbc.SQLServerDriver.
However, when maxinst command is run (maxinst -tPRIMARY -sPRIMARY -imaxdb76), it's failing to read maxdb76.SQS file saying access denied error although user has full permission.
Any suggestions, please?
Error Message:
C:\maximo\maximo\tools\maximo>maxinst -tPRIMARY -sPRIMARY -imaxdb76
!!! WARNING !!!
! Maxinst will drop and rebuild all the tables in your database.
! If you are not sure you should be running Maxinst, hit Ctrl/C now!!!!
! Otherwise,
Press ENTER to continue . . .
Log file: Cleandb20230406124501.log
Connecting to: jdbc:sqlserver://192.168.189.128:1433;databaseName=maxdb76
Cleandatabase complete: Successful
Thu Apr 06 12:45:03 CST 2023 --- Starting ----
BMXAA6806I - Reading the properties file maximo.properties.
java.io.FileNotFoundException: en\maxdb76.sqs (Access is denied.)
at java.io.FileInputStream.open(FileInputStream.java:212)
at java.io.FileInputStream.<init>(FileInputStream.java:152)
at java.io.FileInputStream.<init>(FileInputStream.java:104)
at psdi.configure.Maxinst.endSetupInstance(Maxinst.java:2463)
at psdi.configure.CommonShell.endSetup(CommonShell.java:1722)
at psdi.configure.CommonShell.setup(CommonShell.java:1232)
at psdi.configure.Maxinst.main(Maxinst.java:2551)
java.lang.Exception: Input file en\maxdb76.sqs could not be read.
at psdi.configure.Maxinst.endSetupInstance(Maxinst.java:2478)
Input file en\maxdb76.sqs could not be read. Thu Apr 06 12:45:05 CST 2023
BMXAA6819I - Maxinst completed with errors. Thu Apr 06 12:45:05 CST 2023
