 Maximo labor rate
Jump to  Best Answer
Deepa P's profile image
Deepa P posted 01-16-2025 07:50
Can someone tell me, the laborcraftrate.rate value in maximo, is it in hourly basis? Can someone help me to understand the unit of measurre?
Thank you
Craig Kokay's profile image
Craig Kokay  Best Answer
Hi Deepa,
Quick answer = No.
The only place I can find anything mentioning that it is the hourly payrate is on the work order.
John Yong's profile image
John Yong
Hi Deepa.
Yes, It is in hourly basis.
When entering actual labor hours in the Workorder App, it is calculated as labor hours (regular hours) * rate.
Mia Ilkko's profile image
Mia Ilkko
The unit is of the currency used per hour.
e.g.. Rate= 100 euros/hour ; 2 hours worked hours --> a cost of 200 euros.
Deepa P
Hi John/Mia,
Is there any database field which shows if it in hourly basis ?
I just wanted check if it gets captured in any attribute or not?
Thank you in advance
