 Not able to login to manage after upgrade
Poonam Aswani's profile image
Poonam Aswani posted 07-03-2025 05:07
Hello Maximo Folks,
We have upgraded from 7.6 to MAS 9. Now after upgrade, users are not getting synced to Manage from MAS. We modified existing user/ created a new user but they are failing to sync. Hence, we are not able to login to manage. Any suggestions/ideas which can lead to resolution would be helpful.
Aaron Paroulek's profile image
Aaron Paroulek
Hi Poonam - We had a similar issue recently in our environment in an attempted upgrade to 9.1.  We found that there was a reference to a System Property called: mxe.useradmin, which was undefined in our system (with an Oracle back-end).  With this missing System Property, the MASUSERSYNC Cron Task would run and do nothing.  We went ahead and updated the value, like this:
UPDATE maxpropvalue SET propvalue = 'maxadmin' WHERE propname = 'mxe.useradmin';
After we re-ran the MASUSERSYNC Cron Task, we found that our users had synced over to Core.
Hopefully this work for your as well.
Aaron Paroulek
Maven Asset Management
Poonam Aswani
Hi @Aaron Paroulek, Couldnt reply to your answer, hence posting this way!
I am using db2, should this property exist in db2 also?
Also, this property doesnt exist itself in db2 currently, so shall I insert it in maxprop table, and if yes how will it refresh/take effect? I assume it was existing in your system but not updated with correct value.
Thanks for providing your inputs!
Aaron Paroulek
Good morning - Yes, I think I would try to add the property directly to the maxprop and maxpropvalue tables, even for DB2 (although this did exist for us in Oracle already).  As far as refreshing the property, we were running this update statement to make sure our Cron Task ran: update crontaskinstance SET active = 1 WHERE crontaskname = 'MASUSERSYNC';
We would then just delete the Cron pod, so it would start itself back up, taking the new property values and running our cron task again.  If you aren't using any bundles, then you should be OK to delete your All pod, so everything is refreshed.
Aaron Paroulek
Hariprasad R's profile image
Hariprasad R
Hi Team,
We are facing an issue in our UAT environment after upgrading Maximo Application Suite. Users are not getting synced from MAS Core to Manage, and when we try to access Administration → Users in Core, we get the following error:
BMXAA0029E - You are not authorized to perform this action for this record. Contact your system administrator to request changes to your authorization.
Observations so far:
Logged in with MAS Super user account; can access Core, but user administration in Core shows unauthorized.
MASUSERSYNC cron task exists in DB2 and active = 1 in db
syncagent Logs shows maxadmin user was successfully synced to manage application
2025-10-18 15:31:56,656   usersync-agent-manage           INFO     [maxadmin] Updating user sync state for application manage to SUCCESS
2025-10-18 15:31:56,656   usersync-agent-manage           INFO     url: https://internalapi.mas-uat-core.svc/v3/users/maxadmin/applications/manage/sync
