You need to use an object structure that has WORKORDER at the top and WORKLOG as a child - which MXWO does not have out of the box (it is just WORKORDER).
If you duplicate the MXWO object structure, save it with a suitable name, add WORKLOG to the new object structure (I have used WORKLOGAPPT as the relationship), then use this new object structure in your MxLoader sheet you should achieve what you want. If you want worklog long description, you will need to add that non-persistent field into the structure.
Note in MxLoader your column header names are not correct for referencing a child object. They should be like this:
WONUM
SITEID
WORKLOG.CLIENTVIEWABLE
WORKLOG.CREATEDBY
WORKLOG.CREATEDATE
WORKLOG.DESCRIPTION
WORKLOG.LOGTYPE
WORKLOG.DESCRIPTION_LONGDESCRIPTION
Cameron
Sent: 03-24-2022 05:09
Subject: MxLoader
Did anyone know how to update Work Log in Work Order by using MxLoader? I did tried many times, seems like did not added into work log or doesn't make any changes. Maybe I miss something in MxLoader?
Hopefully got someone know how to do it by using MxLoader.
Nor Herman Afandi
