You should be able to create Object Structures based on a View. I've done it before with Tools and Stocked Tools. Also, there is the MXAPIWMASSIGNMENT Object Structure, but that's used for Integration not Reporting, and it doesn't use any relationships.
Did you check the log files for more info about why it threw the error? I googled that BMXAA4214E code and got lots of varying results, from issues/conflicts with eAudit to the user not having access to the Site the data is coming from.
Sent: 01-17-2021 18:18
Subject: Not able to create Report Object Structure for Assignment Manager application
Since Assignments are on the work order in Work Order Tracking, did you try modifying that object structure to take on the Assignments?
Sent: 01-17-2021 01:10
can anyone please help on this? I am not even sure that is it possible technically to create an Assignment Manager application Report Object Structure?
please suggest
Thank you
