Hi Steven,
You are right, Cordova installation steps provided by IBM documents has issues.
We have reached out to IBM technical Team. Hopefully, we would get some resolution.
Biplab
Biplab Choudhury
Tata Consultancy Services
Sent: 05-21-2020 12:28
Subject: MAXIMO ANYWHERE SSO USING SAML 2.0
We haven't configured it for 7.6.3.1 and I don't have a test Anywhere 7.6.3.1 environment. Looking at the link you had referenced it mentions that upgrading to MobileFirst 7.1 avoids the issue of not being able to install the plugin. Maximo Anywhere 7.6.3.1 is using MobileFirst 7.1, so it seems like the work arounds referenced shouldn't be required anymore. But I do see the link you referenced in the documentation that IBM provides here: https://www.ibm.com/support/pages/enabling-single-sign-sso-security-assertion-markup-language-saml-maximo-anywhere-authentication
It might be best to open a case with IBM support as one of the two documents seems incorrect to me.
Projetech
