We have a requirement, where in we want to
enable/disable "Move/Modify Asset" option based on asset status. So if an asset is operating, users who have access to this option, should not be able use it. For this, we created a condition and associated to required sigoption. This condition works fine in Main tab as one specific MBO is selected. We are facing issue in list tab.
In list tab, maximo considers only the status of highlighted row. If that asset is in "not operating" status and rest of the assets are "operating", it still allows user to use "Move/Modify Asset" option. Also, if "Select Record" is used to select specific records, maximo allows the user to use this action irrespective of asset status.
We don't want to remove this from list tab as this takes out the option to "Move/Modify Asset" in bulk.
I tried implementing the solution mentioned in this link:
How to Control Mass status change within the List Tab
| Ibm |
remove preview |
| How to Control Mass status change within the List Tab |
| Is it possible to hide the change status icon from the list tab? |
| View this on Ibm > |
however, this is not working and creating issues.
Any help would be highly appreciated.
Thanks & Regards.
#Assets#Customizations------------------------------
Amol Pardeshi
Sedin Technologies, India
