  • 1.  DbConnectionWatchDog issue
    Posted 12-20-2021 12:03
    We are getting BMXAA7084I and 7088I messages in logs .
    While trying to start the maximo ui server.
    We have clustered environment.
    The database connection has been opened for 596993140 Ms DbConnectionWatchDog : Db connection reference I'd =17 spid =71.
    We tried stoping the db server restarted the db machine but no luck.
    Tried websphere restart not working.
    Error in calling Script Cache for zombie init event for mbo null. It's coming as warning
    Does anyone has faced the same issue?
    Please advise.
    #Infrastructure
    Sahil Dutta
    xyz
  • 2.  RE: DbConnectionWatchDog issue
    Posted 04-09-2024 07:34
    Hello All - I am also getting the issue below in my UI POD . Can any one help me :-
    09 Apr 2024 11:21:45:130 [INFO ] [dbconnection] BMXAA7088I - DbConnectionWatchDog: Database connection references: 2, open connections: 2, long running references: 2, long running connections: 2 and connection references closed when memory is released: 0
    159209 Apr 2024 11:21:45:172 [INFO ] [maximo] MboSetCounter in memory =0
    159309 Apr 2024 11:22:45:184 [INFO ] [maximo] MboSetCounter in memory =0
    159409 Apr 2024 11:23:45:199 [INFO ] [maximo] MboSetCounter in memory =0
    159509 Apr 2024 11:24:45:204 [INFO ] [maximo] MboSetCounter in memory =0
    159609 Apr 2024 11:25:45:207 [INFO ] [maximo] MboSetCounter in memory =0
    159709 Apr 2024 11:26:45:208 [INFO ] [maximo] MboSetCounter in memory =0
    159809 Apr 2024 11:27:45:210 [INFO ] [maximo] MboSetCounter in memory =0
    159909 Apr 2024 11:28:45:215 [INFO ] [maximo] MboSetCounter in memory =0
    160009 Apr 2024 11:29:45:220 [INFO ] [maximo] MboSetCounter in memory =0
    Biswa
    Biswaranjan Biswaranjan
    TCS
