  • 1.  Adding Inspection Forms to Jon Plan
    Posted 10-28-2021 09:00
    I am trying to add an inspection form to a job plan and i am getting the following error message: "BMXAA0019I - The Organization field is either read only or part of the primary key. You cannot edit this field."  The ORGID and SITEID are blank for this job plan.  I can't tell if the inspection form has an ORGID or SITEID assigned within Maximo and I don't have database access on the backend to be able to search the tables.  I know there are rules regarding the use of Job Plans within ORGs and SITEs.  Are there similar rules for Inspection Forms?
    #Transportation
    #WorkCenters
    Steve Sentz
    Sentz Consulting Inc.
  • 2.  RE: Adding Inspection Forms to Jon Plan
    Maximo Certified
    Posted 11-15-2021 15:28
    Hi Steve,
    Inspection forms are at ORG level, a somewhat annoying feature.
    I have tried multiple scenarios and cannot produce the error you have experienced, therefore I look towards the steps leading towards you getting the error.
    Q: What status is the form?
    Q: Is the inspection form being added to the main body or the task?
    Q: What is the sequence that you are adding the inspection form?
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2021
