  • 1.  Adding inspection form on newly saved / revised job plan
    Posted 12-08-2025 13:02
    Hello Maximo community,
    Any idea, why the inspection form field on a newly created and saved job plan or revised job plan raises the following error ? bmxaa0019i - the organization field is either read only or part of the primary key. you cannot edit this field.
    The inspection form has orgid and siteid. Even I add these to the job plan and save, and then try to add the inspection form, the same issue arises.
    Any idea of this standard behavior?
    Oumayma Azouz
    AtkinsRealis
  • 2.  RE: Adding inspection form on newly saved / revised job plan
    Posted 12-09-2025 08:49
    What is happening here is the inspection form would try to set the ORGID field on the job plan. As you mentioned, all inspection forms will have an ORGID (and most will have a siteid, though the siteid is currently meaningless from a Maximo perspective). Because an inspection form is required to be at the ORG level today, it won't work on system level job plans (no ORGID on the job plan) since those could be applied to a different ORG that can't utilize the inspection form.
    You can't change the job plan in a supported way to add an ORGID, even during revisions. You would need to create a new job plan with an ORGID specified.
  • 3.  RE: Adding inspection form on newly saved / revised job plan
    Posted 12-10-2025 05:08
    Thank you for your reply. Very helpful.
    Oumayma Azouz
    AtkinsRealis
