  • 1.  OPEN PO Alert before Closing a WO
    Posted 12-26-2025 12:26
    Edited by Danny Richardson 12-26-2025 12:27
    I was curious if Maximo out of the box has a setting so that it warns you of an open PO before closing a work order?
    It seems that if you close a work order and have a PO that has not been received it will not allow you to receive the PO.
    So if there is not an out of the box option, I'm considering creating an automation script to warn the user, or even block the closing of a work order if there is an open PO not yet received.
    Or if there is anything best practice to consider with closing Work Orders and open PO's I'd love to hear any advice.
    Thank you in advance,
    #Procurement
  • 2.  RE: OPEN PO Alert before Closing a WO
    Posted 12-29-2025 10:49
    Maximo provides a warning out of the box when a work order is closed that is referenced on a PO that is not fully received. You could add additional logic (such as an automation script) to fully prevent this status change if desired.
    Generally, I recommend customers don't close work orders via a manual process. I've seen too many situations where users bulk close work orders and there's no good way to recover them. Edit history can be used but it's quite painful. Normally I recommend an escalation that looks for things like the work order is in a COMP status, has not been modified in X days (30, 90, etc.), is not referenced on an open PO, etc.
  • 3.  RE: OPEN PO Alert before Closing a WO
    Posted 12-30-2025 09:28
    I agree wholeheartedly with Steven.  Remove the Close Work Order action from (almost) all users, except for Sys Admins and MAYBE a Power User you really trust to understand the whole Work Order lifecycle.  Create an Escalation to do the Close action.  Set the Escalation's WHERE clause to affect only WOs that don't have anything left "open" -- unapproved Labor Transactions; references in MRs, PRs, POs, or Invoices where those records aren't closed out; possibly even if it has Children WOs with any of those same symptoms; etc.
  • 4.  RE: OPEN PO Alert before Closing a WO
    Posted 12-31-2025 09:46
    Thank you @Travis Herron.  We have an escalation, but I haven't thought about updating the where clause like you are suggesting.
  • 5.  RE: OPEN PO Alert before Closing a WO
    Posted 12-31-2025 09:44
    Edited by Danny Richardson 12-31-2025 09:46
    Thank you @Steven Shull. Does that mean then that you would filter out COMP work orders from the List View screen in Work Order Tracking or Quick Reporting?
  • 6.  RE: OPEN PO Alert before Closing a WO
    Posted 01-02-2026 11:16
    Given the volume of work orders in most customer systems and how inefficient QBR searches can be, I think most people should have saved queries they utilize rather than building out searches on the fly each time. We use start center portlets that filter out completed work orders and people navigate into the application using those queries. We don't explicitly filter out COMP work orders with an application restriction or anything like that because there are reasons someone would need to see them.
  • 7.  RE: OPEN PO Alert before Closing a WO
    Posted 12-30-2025 09:44
    I recently had a similar requirement while migrating our triggers off our DB into automation scripts. It's an launch point on the status attribute. Here is a starter template for what I came up with. I'm still testing it before moving into production. But I think it's pretty close to the workflow that you're looking for.
    With that said, we don't allow our users to manually close work orders.  All they can do is put them into a "Completed" status. We then have a batch job that will run 90 days after they are in that status to finally close them.
    from psdi.util import MXApplicationException
    # Script Name: VAL_WO_STATUS
    # Launch Point: Attribute - WORKORDER.STATUS - Validate
    # Logic: Prevents Close/Bill/Cancel if open Children or POs exist.
    # 1. Define the "Gatekeeper" statuses
    stop_statuses = ['CLOSE', 'BILLPREP', 'CAN', 'COMP']
    # Get the status the user is trying to change to.
    # Return the NEW value currently in memory.
    pendingStatus = mbo.getString("STATUS")
    if pendingStatus in stop_statuses:
        # 2. PM Bypass Rule
        #    If this WO came from a PM (Preventive Maintenance), we skip all checks.
        pmnum = mbo.getString("PMNUM")
        if not pmnum:
            # Get current WO details
            wonum = mbo.getString("WONUM")
            siteid = mbo.getString("SITEID")
            # CHECK 1: Open Child Work Orders
            where_children = "parent = '{}' and siteid = '{}' and status not in ('CAN','CLOSE','BILLPREP')".format(wonum, siteid)
            childSet = MXServer.getMXServer().getMboSet("WORKORDER", mbo.getUserInfo())
            childSet.setWhere(where_children)
            if not childSet.isEmpty():
                # We found open children! Stop the user.
                params = [wonum]
                # Ensure "openchildren" exists in Database Config > Messages
                raise MXApplicationException("workorder", "openchildren", params)
            childSet.close()
            # CHECK 2: Open Purchase Orders (Directly on this WO)
            where_po = "refwo = '{}' and siteid = '{}' and exists (select 1 from po where po.ponum=poline.ponum and po.revisionnum=poline.revisionnum and po.siteid=poline.siteid and po.status not like 'C%' and po.status <> 'REVISD')".format(wonum, siteid)
            poLineSet = MXServer.getMXServer().getMboSet("POLINE", mbo.getUserInfo())
            poLineSet.setWhere(where_po)
            if not poLineSet.isEmpty():
                service.error("po", "openpo_on_wo")
                # raise MXApplicationException("po", "openpo_on_wo")
            poLineSet.close()
            # CHECK 3: Open POs on Child Work Orders
            where_child_po = "refwo in (select wonum from workorder where parent='{}' and siteid='{}') and siteid = '{}' and exists (select 1 from po where po.ponum=poline.ponum and po.revisionnum=poline.revisionnum and po.siteid=poline.siteid and po.status not like 'C%' and po.status <> 'REVISD')".format(wonum, siteid, siteid)
            childPoSet = MXServer.getMXServer().getMboSet("POLINE", mbo.getUserInfo())
            childPoSet.setWhere(where_child_po)
            if not childPoSet.isEmpty():
                service.error("po", "openpo_on_childwo")
                # raise MXApplicationException("po", "openpo_on_childwo")
            childPoSet.close()
            # CHECK 4: Open Purchase Requisitions (Directly on this WO)
            # Checks PRLINEs linked to this WO where the PR header is not Closed (CLOSE) or Cancelled (CAN)
            where_pr = "refwo = '{}' and siteid = '{}' and exists (select 1 from pr where pr.prnum=prline.prnum and pr.siteid=prline.siteid and pr.status not like 'C%')".format(wonum, siteid)
            prLineSet = MXServer.getMXServer().getMboSet("PRLINE", mbo.getUserInfo())
            prLineSet.setWhere(where_pr)
            if not prLineSet.isEmpty():
                service.error("pr", "openpr_on_wo")
                # raise MXApplicationException("pr", "openpr_on_wo")
            prLineSet.close()
            # CHECK 5: Open PRs on Child Work Orders
            where_child_pr = "refwo in (select wonum from workorder where parent='{}' and siteid='{}') and siteid = '{}' and exists (select 1 from pr where pr.prnum=prline.prnum and pr.siteid=prline.siteid and pr.status not like 'C%')".format(wonum, siteid, siteid)
            childPrSet = MXServer.getMXServer().getMboSet("PRLINE", mbo.getUserInfo())
            childPrSet.setWhere(where_child_pr)
            if not childPrSet.isEmpty():
                service.error("pr", "openpr_on_childwo")
                # raise MXApplicationException("pr", "openpr_on_childwo")
            childPrSet.close()
    Brett Coleman
    Georgia Building Authority
  • 8.  RE: OPEN PO Alert before Closing a WO
    Posted 12-31-2025 09:49
    Thank you @Brett Coleman.  I appreciate you sharing the script as a possible starting point.  How do you handle users seeing most recent, relative work orders if work orders stay on the list view for 90 days?  Do you teach them how to filter or do you have an automatic filter set up?
  • 9.  RE: OPEN PO Alert before Closing a WO
    Posted 01-01-2026 13:01
    HI @Danny Richardson - we have set up a start center portlet using a query that filters the reverse of the escalation, so that they will only see work orders that don't meet the criteria for closure, meaning something must be done about them.
    For example, If a work has no open POs or PRs, is not safety critical, has no compliance markers on it (that's a custom field for us), is in COMP, has failure reporting (based on worktype) and has actual hours entered against us, it won't appear in their start centre, and the escalation will take care of it overnight.
    (We dropped the 90 day delay because we found nobody touched the work orders for 90 days anyway, based on all the criteria above they were finished.)
    Craig Webber
    Mercury NZ
  • 10.  RE: OPEN PO Alert before Closing a WO
    Posted 01-05-2026 11:11
    We created a COMP synonym called WCLOSE.  All COMP tickets have to be reviewed by a lead, so to distinguish those in COMP waiting to be reviewed and those already reviewed and awaiting a PO/Invoice closure, we created the other status.  We have our escalation set to 7 days before it closes on its own as it's very rare someone needs to change the WO where Edit WO History can't handle it.  And we did exclude WCLOSE from all default WO query page and all WO queries in general.
    gail smith
    chevrongail smith
    chevron
