  • 1.  Manage Inspection Form Cards - can new fields be added?
    Posted 07-08-2021 12:04
    Edited by Joe Kelley 07-08-2021 14:04
    Has anyone figured out how to add additional fields or information on the Manage Inspection Form cards?  We see an additional description field that can be updated on the back end and would like it to show on the card.
    #WorkCenters
    Wayde Prejean
    Kinder Morgan Inc.
  • 2.  RE: Manage Inspection Form Cards - can new fields be added?
    Posted 07-11-2021 03:22
    Hi Wayde,
    Inspection forms are configurable to great extent.
    Can you give us the exact requirement?
    Also, You can customize the work centers to a great extent. Problem is I am not sure how much of it will work in the future work centers as I hear that IBM is going to move away from the current google Polymer JS to REACT js based carbon UI.
    Biplab
    Biplab Choudhury
    Tata Consultancy Services
  • 3.  RE: Manage Inspection Form Cards - can new fields be added?
    Posted 07-13-2021 09:55
    Hi Wayde,
    In order to configure work center cards (in more depth than what you can do from the front end) you'll need to have access to the install folder.
    [MaximoInstallLocation]/SMP/maximo/applications/maximo-x/script/maximocards/inspection/inspector
    Once there you can navigate to the desired folder and in the folder you'll have three files: HTML, CSS-HTML, JS.
    Once the updates are complete you'll need to deploy the maximo-x.ear to your app server.
    Please reach out if you have any questions.
    Matt
    Matt McGuire
    Aquitas Solutions
