  • 1.  Manage Inventory Work Centers
    Posted 08-12-2021 08:41
    Are the MAX Objects required for this work center in OOB 7.6.1.2 Maximo Asset Management?  Can someone tell me where to find them as I do not see them in DB Config>Objects.
    Charles
    #Architecture
    Charles Bowers
  • 2.  RE: Manage Inventory Work Centers
    Posted 08-13-2021 09:08
    Hi Charles,
    The Work Center objects are not available in the DB Config. You have to view the m in the Object Structures application.
    IBM provides good documentation on setting up work centers at this link 7611 Work Centers
    Matt McGuire
    Aquitas Solutions
  • 3.  RE: Manage Inventory Work Centers
    Posted 08-16-2021 10:45
    Hi Charles,
    All the objects are there in DB Config. There is a flag called internal in the db config. You can set it to null to search all the objects.
    Curious to know,  what do you man by "Are the MAX Objects required for this work center in OOB 7.6.1.2 Maximo Asset Management? " ?
    Biplab Choudhury
    Tata Consultancy Services
