LDAP over SSL
  • 1.  LDAP over SSL
    Posted 22 days ago
    Gentlemen experts, good health to all!
    I need some advice!
    I had LDAP authentication configured via the standard port 389.
    I need to configure LDAP over SSL. I'm setting the SSLEnabled parameter to true. I'm changing the connection port to 636.
    I'm getting an error in the log. I'd like to know how to fix this?
    [INFO] [MAXIMO] [CID-CRON-3632] Correlation started, correlation data added: InstanceName:LDAPS-TEST TaskName:LDAPSYNC Activity:ACTION
    [10.03.26 20:04:27:617 MSK] 000000f7 SystemOut O Mar 10, 2026 20:04:27:613 [ERROR] [MAXIMO] [CID-CRON-3632] BMXAA6765E - The LdapSyncCronTask cron task could not be started. This message will be repeated if the initialization fails when the task runs again. See the associated message.
    psdi.security.ldap.LdapSyncException: BMXAA6774W - The rootDSE attribute for attribute name highestCommittedUSN was not found.
    at psdi.security.ldap.ads.ActiveDirectorySynchronizer.getRootDSEAttributeValue(ActiveDirectorySynchronizer.java:731) ~[businessobjects.jar:?]
    at psdi.security.ldap.ads.ActiveDirectorySynchronizer.determineSynchronizationNeed(ActiveDirectorySynchronizer.java:617) ~[businessobjects.jar:?]
    at psdi.security.ldap.AbstractLdapSynchronizer.performSync(AbstractLdapSynchronizer.java:278) ~[businessobjects.jar:?]
    at psdi.security.ldap.LdapSyncTask.performTask(LdapSyncTask.java:391) ~[businessobjects.jar:?]
    at psdi.security.ldap.LdapSyncCronTask.cronAction(LdapSyncCronTask.java:262) [businessobjects.jar:?]
    Sergey Melnikov
    RusNet
  • 2.  RE: LDAP over SSL
    Posted 22 days ago
    You want to ensure you follow the instructions here: Authentication error when running LDAPSYNC.
    In addition to the port that you connect to LDAP on, there is a catalog port that it uses to try and traverse the forest. If you have a VPN (in a cloud environment), you'll need to ensure the port access is opened as well.
    I personally prefer using VMMSync rather than LDAPSync. This would connect to WebSphere to pull users and groups rather than requiring duplicate LDAP configuration (in WebSphere and Maximo) and avoid the use of the global catalog port and such. But if you were previously using LDAP sync it's certainly easier to get it to work over SSL than switching your process.
  • 3.  RE: LDAP over SSL
    Posted 21 days ago
    Steven, thank you very much for your reply!
    Sorry, I should have described my configuration first.
    Maximo 7.6.1.3 is on the local network and runs on Windows Server 2025.
    I tried connecting via SSL through Websphere.
    To do this, I pulled the certificate from the port, specified the AD server IP address and port 636, enabled the SSL checkbox, entered the username and password of a user who can read AD, and received an error when attempting a test connection.
    SECJ7340E: An exception occurred while trying to connect to the LDAP server. Exception Name=javax.naming.CommunicationException Reason=192.168.80.14:636 ***** LdapSearch Input Parameters ***** hostName=192.168.100.11 portNumber=636 sslEnabled=true sslAlias=CellDefaultSSLSettings baseDN=DC=vr,DC=local bindDN=maxbind bindPwd=***** bindAuthMechanism=simple searchFilter=cn=* searchLimit=20 referral=ignore searchScope=sub
    Sergey Melnikov
    RusNet
  • 4.  RE: LDAP over SSL
    Posted 21 days ago
    IP addresses on insecure ports are OK, but when you use LDAPS, you'll have a hostname mismatch where your certificate will be for a DNS, not an IP address. Your certificate might be issued to ad1.myorg.com for example. If you can't utilize that DNS from the server, you'll need to create a host entry on the server mapped back to the IP address so that it passes.
  • 5.  RE: LDAP over SSL
    Posted 20 days ago
    Steven, thank you so much for your reply. Your comment about DNS is very valuable and fair. I'll delegate this to the network administrator.
    Recently, I've made it so everyone uses only IP addresses without DNS names. There was a time when the network administrator couldn't fix DNS for two weeks, which was quite inconvenient.
    Sergey Melnikov
    RusNet
  • 6.  RE: LDAP over SSL
    Posted 21 days ago
    Besides requiring a FQDN, you might ask your server/network admin if you have a load balancer handling the security certificate. This is common in enterprise settings. I see two IP addresses, which could mean one of them is the load balancer. After you use FQDN (fully qualified domain name), you may get another error message to help you narrow the error down.
    sun kim
  • 7.  RE: LDAP over SSL
    Posted 20 days ago
    Sun Kim, good day!
    Thanks for your reply.
    No, there's no balancer. It's my fault. I entered the wrong IP address. This happens when you're multitasking.
    Here's the error with the correct IP addresses.
    These are the addresses of the server hosting the AD.
    SECJ7340E: An exception occurred while trying to connect to the LDAP server. Exception Name=javax.naming.CommunicationException Reason=192.168.80.14:636 ***** LdapSearch Input Parameters ***** hostName=192.168.80.14 portNumber=636 sslEnabled=true sslAlias=managed baseDN=DC=vr,DC=local bindDN=maxbind bindPwd=***** bindAuthMechanism=simple searchFilter=cn=* searchLimit=20 referral=ignore searchScope=sub
    Sergey Melnikov
    RusNet
  • 8.  RE: LDAP over SSL
    Posted 20 days ago
    If you're going to use Secure LDAP, you can't use IP address. It has to be a fully qualified domain name (FQDN) - for example, maximo.rusnet.com
    sun kim
  • 9.  RE: LDAP over SSL
    Posted 19 days ago
    sun kim
    Good day!
    Thank you for your reply!
    The server is on the local network, so its name is SRV04.vr.local. I tried a test request and got this error.
    Apparently, the server administrator doesn't have SSL enabled.
    SECJ7340E: Exception occurred while trying to connect to the LDAP server. Exception Name=javax.naming.CommunicationException Reason=SRV04.vr.local:636 ***** LdapSearch Input Parameters ***** hostName=SRVH04.vr.local portNumber=636 sslEnabled=true sslAlias=CellDefaultSSLSettings baseDN=DC=vr,DC=local bindDN=maxbind bindPwd=***** bindAuthMechanism=simple searchFilter=cn=* searchLimit=20 referral=ignore searchScope=sub
    Sergey Melnikov
    RusNet
  • 10.  RE: LDAP over SSL
    Posted 16 days ago
    I'd be surprised if LDAP over SSL is not turned on. More likely, the port used to access the server (port 636) is blocked. Talk to your network admin to confirm. And in the off chance that LDAPS (LDAP over SSL) is disabled, you'd need to discuss with the server admin to enable it.
    Even though this is a local network, bindAuthMechanism=simple means the passwords are sent in cleartext across the local network. I don't know of any IT department that won't help with securing the network, so hopefully they can assist you quickly.
    sun kim
  • 11.  RE: LDAP over SSL
    Posted 9 days ago
    Сун Ким, доброго дня!
    Большое спасибо за совет; я только сегодня добрался до форума.
    Мне наконец-то удалось настроить IBM Websphere для использования SSL на порту 636. Для тестирования я создал нового пользователя в Active Directory, и он был добавлен в IBM Websphere.
    После этого я попытался настроить IBM Maximo, но был разочарован этой ошибкой.
    [ERROR] [MAXIMO] [CID-CRON-10325] BMXAA6765E - Не удалось запустить задачу cron LdapSyncCronTask. Это сообщение будет повторяться, если инициализация завершится неудачей при повторном запуске задачи. См. соответствующее сообщение.
    psdi.security.ldap.LdapSyncException: BMXAA6774W - Атрибут rootDSE для имени атрибута highestCommittedUSN не найден.
    Буду очень благодарен за любой совет.
    Sergey Melnikov
    RusNet
  • 12.  RE: LDAP over SSL
    Posted 9 days ago
    Edited by sun kim 9 days ago
    System Configuration > Platform Configuration > Cron Task Setup
    This parameter should 9th option. Change from port 3268 to 3269.
    Steve already posted the URL, but worth repeating:
    https://www.ibm.com/support/pages/authentication-error-when-running-ldapsync
    https://web.archive.org/web/20260323191556/https://www.ibm.com/support/pages/authentication-error-when-running-ldapsync
    Resolving The Problem
    To resolve this problem, the following attributes need to be set to the correct values in the Cron Task Cron Task Setup Application for LDAPSYNC task:
    Port -- 636
    SSLEnabled -- true
    SynchParmater -- globalcatalogport=3269
    After making the above changes, you will need to reload the cron task and review the systemout.log to confirm the error is not seen.
    Following are the combination for the Port and globalcatalogport settings:
    If using SSL:
    SSLEnabled: true (not 1)
    Port: 636
    Catalog Port :3269
    If Not using SSL:
    SSLEnabled: False (not 0)
    Port: 389
    Catalog Port: 3268
    sun kim
  • 13.  RE: LDAP over SSL
    Posted 8 days ago
    Sun Kim, good afternoon!
    Thank you for your time!
    I attached two screenshots to my previous message; I even went to look at them again.
    I have everything as you described: ports 636 and 3269. I dug deeper into the logs, and as far as I can tell, Maximo doesn't trust the AD server certificate since it's located within the local network and is itself an internal CA.
    I don't know what to do about this yet, and I don't understand why IBM Websphere isn't having any problems?
    Sergey Melnikov
    RusNet
  • 14.  RE: LDAP over SSL
    Posted 7 days ago
    We use Public CAs now, we don't use internally self-signed certificates. Our server admin usually handles stuff like this, but from my notes I want to say WebSphere is one layer for the certs and Maximo uses a different store based on the Java JDK . You need to get a copy of the Windows AD cert (self_signed_ad_cert.cer), and import that into java cacerts file on for the Java Maximo is using.
    I think the SystemOut.log will say what path you're using for Java, or if you go to Task Manager in Windows, look for java.exe using the most memory and open file location to see the path.
    The file cacert file something in a location like this: C:\IBM\WebSphere\AppServer\java\8.0\jre\lib\security\
    Backup the cacerts file before changing it (just in case)
    Use the keytool, to import the self_signed.cert
    keytool -import -trustcacerts -alias myInternalAD -file "C:\path\to\self_signed_ad_cert.cer" -keystore cacerts
    If successful, you restart MXServer.
    This is really not my area,
    sun kim
  • 15.  RE: LDAP over SSL
    Posted 2 days ago
    Sun Kim, good day!
    I downloaded the certificate from port 636, it's in the certificate store. The problem is, when I try to access the AD server via HTTPS, I see an invalid certificate from last year in IIS.
    I can't get the administrator to figure out why this is happening. I'm thinking about VMMSync. Maybe if I authenticate users through Websphere, I won't be dependent on the server administrator sorting out the certificates?
    Sergey Melnikov
    RusNet
  • 16.  RE: LDAP over SSL
    Posted 2 days ago
    Steven, good day to you!
    I've given up on getting the admin to create a valid certificate for the AD servers. When I try to access the AD server, I see an expired certificate.
    Perhaps I should bypass LDAPSync and configure VMMSync. My question is, will user authentication be possible through VMMSync? How does this mechanism work?
    Sergey Melnikov
    RusNet
  • 17.  RE: LDAP over SSL
    Posted yesterday
    If the security certificate is expired, you need to renew it for another year or two.
    sun kim
