  • 1.  RESTAPI Call Not returning ALL PO Lines
    Posted 06-10-2024 17:49
    When I'm making a call using the MXPO Object Structure I'm not returning all PO line information.  For example, my PO has 9 lines and I am trying to GET the
    ponum,totalbasecost,status,POLINE.POLINEID,poline.polinenum,poline.linecost,poline.pocost.percentage
    When my result is returned I am only getting the first PO Header information and 1st PO Line information.
    Any ideas on why the other line information is not being returned?
    Adam Olson
    Deriva Energy
  • 2.  RE: RESTAPI Call Not returning ALL PO Lines
    Posted 06-11-2024 11:10
    Adam,
    Try the following as your oslc.selectString parameter:
    ponum,totalbasecost,status,poline{polineid,polinenum,linecost,pocost{percentage}}
    You can also use the following syntax if the objects do not exist in the object structure and you just want to use standard relationships:
    ponum,totalbasecost,status,rel.poline{polineid,polinenum,linecost,rel.pocost{percentage}}
    Hope this helps,
    Alex Walter
    A3J Group LLC
  • 3.  RE: RESTAPI Call Not returning ALL PO Lines
    Posted 06-15-2024 12:01
    Thank you Alex! This worked for me
    Adam Olson
    Deriva Energy
