  • 1.  ATTACHMENT NAME SHOULD NOT EXCEED 50 IN MAXIMO
    Posted 01-24-2023 01:33
    Hello Everyone,
    I am not able to attach the file which is having the file/url name (character length of url/file name) more than 50. How can we change the character of the file name to be more than 50, so that we can attach the file/url which has more than 50 characters.
    Getting the error as 'B
    If the URL or file name of the attachment is more than 50.How can i change the length of the file/URL name to be 100 characters?
    Thanks in Advance
    Sowndarya Seshadri
    Accenture
  • 2.  RE: ATTACHMENT NAME SHOULD NOT EXCEED 50 IN MAXIMO
    Posted 01-24-2023 06:01
    Hello - if you look at the error you are getting it has the code BMZZ in error which means it is a custom code from which this error is being thrown.
    It is not out of box maximo error so you need to check any automation script or java class file assocaited with DOCLINKS or DOCINFO table where you'll see the length that has to be changed to 100.
    Sedin Technologies
    #IBM Champion 2022
  • 3.  RE: ATTACHMENT NAME SHOULD NOT EXCEED 50 IN MAXIMO
    Posted 01-24-2023 10:53
    Yes, there is a java class file. Issue resolved.
    Thanks Prashant.
    Sowndarya Seshadri
    Accenture
