  • 1.  AutoScript migration with MXLoader in MAS instance
    Posted 08-14-2023 03:40
    Hi Everyone, Greetings for the day!!
    We have used MXLoader for migrating components in MAS8, but observing inconsistent behavior with AutoScript.
    1. we query the script along with the source code form source environment with MXLoader
    2. then we push that AutoScript to the target environment with MXLoader
    3. We see source code in target environment with multiple line spacing getting introduced, however Script executes fine in target.
    4. we change the source code manually in target environment and script does not execute at all until we migrate that script again OR copy the entire source code manually from source environment to target.
    Has anyone here observed the inconsistent behavior of the AutoScript after migrating the same with MXLoader? Any thought is appreciated.
    Pradnya
    @Yashas Sanketi
    Pradnya Maximo
    EY GDS
  • 2.  RE: AutoScript migration with MXLoader in MAS instance
    Posted 08-18-2023 12:51
    Hi, I have just fixed this annoying issue.
    Can you please try to download the latest version (8.4) and retry?
    Regards
    Bruno Portaluri (MaximoDev)
  • 3.  RE: AutoScript migration with MXLoader in MAS instance
    Posted 08-21-2023 08:41
    Hi @Bruno Portaluri,
    Thank you for the quick turnaround.
    Latest MXLoader version(8.4) seem to be working fine; No line spacing in the migrated automation script source code and also script compiles fine even if we manually edit the script code in target environment.
    Pradnya
    Pradnya Maximo
    EY GDS
