  • 1.  Can add Address info in MXPERSON but cannot remove and make fields blank
    Posted 04-26-2024 12:45
    Hello all,
    I noticed that I can add Address info in MXPERSON but cannot remove and make blank.
    I did not choose delete because I did not want to delete the record, so I just removed the text from the field and chose Change and Add/Change but it did not remove it in Maximo.
    Any suggestions? Or is it not supposed to remove text from fields only edit them?
    Thank you
  • 2.  RE: Can add Address info in MXPERSON but cannot remove and make fields blank
    Posted 04-26-2024 13:56
    Hi Danny! I haven't reviewed it, but I'll respond quickly. If you query a person pointing to MXPERSON ("query" method) and you can see the address, then you delete it and synchronize call the "Sync-AddChange" or "Sync-Change" method, it should delete the data from the field.
    Tell me if it doesn't work for you and I'll try it here.
  • 3.  RE: Can add Address info in MXPERSON but cannot remove and make fields blank
    Best Answer
    Posted 04-29-2024 09:09
    Danny,
    I'm not sure if this will do what you're looking for, but I was told that if I wanted to clear data from a field I should put the reserved word ~NULL~ in the MXLOADER cell for the field I was trying to remove the data from.
    Hope this helps.
    Jim
    Jim Dutton
    Battle Lumber Company
