  • 1.  Cannot load INVBALANCES. USEBY using INVBALNACE
    Posted 14 days ago
    I am trying to load balance details  of lotted item . All the data gets uploaded except for Expiration date (INVBALNCES.USEBY)
    I don't get any error and system loads binum, lot, balance etc. I am not loading shelf days.
    I understand this field is not non-persistent, but when i try to load directly to INVLOT.USEBY, it gives error
    Naveed Wasay
    Serco
  • 2.  RE: Cannot load INVBALANCES. USEBY using INVBALNACE
    Posted 11 days ago
    Non-persistent fields are excluded on the object structure by default. In the Object Structures application, have you ensured this attribute is included on the object structure? If you're not sure, there's an action called Exclude/Include Fields that will open a dialog for the object structure you're using. Go to the non-persistent tab and ensure USEBY is included.
    If you've done that and it still doesn't work let me know because it should. I can test this out in one of our demo systems.
  • 3.  RE: Cannot load INVBALANCES. USEBY using INVBALNACE
    Posted 9 days ago
    Hi
    Thanks for help,
    Its working
    Naveed Wasay
    Serco
