  • 1.  Error 400: BMXAA4210E - Suggestions for Fixing a SQL Query?
    Posted 07-17-2026 12:51
    Hi there,
    I'm having an issue with creating queries that include specifications for my hierarchypath field.
    my current SQL is; hierarchypath LIKE '%SUBSTATION \ NO MODIFIER%'
    This is the error message; Error Code 400: BMXAA4210E - Database error number 207 has occurred. Invalid SQL queries are logged in the log file. Check the SQL query to identify the error.
    My first thought was that this error maybe caused by the delimiter in the query term, but even terms without the delimiter are causing this error. The syntax of the query works perfectly when searching other fields, and 'hierarchypath' is being successfully used to pull values in the sheet that I'm trying this query on.
    Does anyone have any suggestions on how to correct this? or even how to check the log file? I'm a newer user of MX Loader so I'm hoping this issue is due to my inexperience.
    Any advice is appreciated! Thank you.
    Sophia C
  • 2.  RE: Error 400: BMXAA4210E - Suggestions for Fixing a SQL Query?
    Posted 07-17-2026 14:04
    Hierarchy path is a non-persistent attribute in Maximo. This means you can retrieve the data using object structures, but you can't filter on them since Maximo converts the filter into a SQL where clause. We've created views in the database that build out the hierarchy path which you could do here. Or you could create a relationship from your table to CLASSSTRUCTURE with something like:
    classstructureid in (select classstructureid from classstructure where classificationid like 'NO MODIFIER%' and parent in (select classstructureid from classstructure where classificationid like '%SUBSTATION'))
    I would caution if you have a lot of classifications, like statements like this aren't efficient. It might be worth adding a custom field instead to search on.
  • 3.  RE: Error 400: BMXAA4210E - Suggestions for Fixing a SQL Query?
    Posted 07-17-2026 18:49
    Ahhh that makes a lot of sense, Steven. I really appreciate your explanation; it helped me with my understanding of MX Loader and Maximo both more than you know.
    Thank you!
    Sophia Cafouros
    Yellow Valley Resources LTD.
  • 4.  RE: Error 400: BMXAA4210E - Suggestions for Fixing a SQL Query?
    Posted 07-20-2026 21:50
    Hi Sophia,
    Steven's observation is accurate that the hierarchypath is a non-persistent Maximo attribute, so the displayed value is not stored as a simple physical database column.
    However, non-persistent does not mean impossible to query, validate, or reproduce. It means the value is derived through Maximo application logic. In Maximo's Database Configuration Application, the Maximo data dictionary, MBO relationships, and Java classes behind the asset catalog objects, that logic is related to the ASSETCATALOG Maximo Service. Please see the attached Maximo ERD.
    The classification hierarchy and specification configuration can be rebuilt from the persistent Maximo asset catalog and classification tables. Please see the attached queries, validated in SQL Server and Oracle databases, but need validation in DB2.
    It is possible to further drill down into Maximo Objects to further validate data at the Object level. Let me know if you have any questions; I've used the logic extensively over the past eight years in DB2, Oracle, and SQL Server databases.
    Key Maximo Objects, Java Classes, and Descriptions
    Object / Table
    Java Class / MBO Set
    Object Description
    ASSETATTRIBUTE
    psdi.app.assetcatalog.AssetAttributeSet
    Attribute or property of an asset, item, or location.
    CLASSANCESTOR
    psdi.app.assetcatalog.ClassAncestorSet
    Class structure ancestors used to rebuild classification hierarchy.
    CLASSIFICATION
    psdi.app.assetcatalog.ClassificationSet
    Classification used to categorize assets and related records.
    CLASSSPEC
    psdi.app.assetcatalog.ClassSpecSet
    Classification template for asset specification attributes. Maximo Java documentation describes ClassSpec as the MBO representing class specifications and notes that key attributes include ClassStructureId, Section, and AssetAttrId.
    CLASSSPECUSEWITH
    psdi.app.assetcatalog.ClassSpecUseWithSet
    ClassSpec use-with table. Defines where class specification attributes are used.
    CLASSSTRUCTURE
    psdi.app.assetcatalog.ClassStructureSet
    Structured hierarchy of asset classifications. Maximo Java documentation describes ClassStructure as the MBO representing class structure and states that ClassStructureId is the primary unique identifier. [ibm.com]
    CLASSUSEWITH
    psdi.app.assetcatalog.ClassUseWithSet
    Contains class structure use-with information.
    FEATURESPEC
    psdi.app.feature.FeatureSpecSet
    Feature specification table.
    LINKCLASSSPEC
    psdi.app.assetcatalog.virtual.LinkClassSpecSet
    Non-persistent table for linking specifications to an asset.
    LNKCLAUSEATRNAME
    psdi.app.rcnlnkrule.ReconLinkClauseSet
    Joins CLASSSPEC and ASSETATTRIBUTE.
    MEASUREUNIT
    psdi.app.assetcatalog.MeasureUnitSet
    Measurement units used by classification/specification attributes.
    SEARCHATTRIBUTE
    psdi.app.assetcatalog.virtual.SearchAttributeSet
    Non-persistent table for attribute search.
    Please use the SQL queries that rebuild and validate the classification hierarchy and specification configuration from these underlying Maximo objects.
    These queries provide both summary and detail analysis for: I did not provide the query in the last column, the reference is an example of the ability to extend the logic to drill down into each classification's actual data, to draw meaningful insights.
    Analysis Area
    What the Queries Validate or Reconstruct
    Classification hierarchy
    Rebuilds the hierarchy path from CLASSSTRUCTURE and CLASSANCESTOR.
    Parent / child classifications
    Identifies parent classifications and child classification paths.
    Use-with configuration
    Shows where classifications and class specifications are used.
    Classification specifications
    Lists classification attributes and specification configuration.
    Attribute sequence
    Validates attribute/specification order.
    Attribute metadata
    Shows data type, domain, measure unit, and description-generation settings.
    Attribute/specification counts
    Summarizes number of specifications by classification.
    Loaded classified assets
    Validates classified asset records and loaded asset specification completeness.
    ASSET CATALOG ERD:
    CLASSIFICATIONS ERD:
    SQL SERVER QUERY EXAMPLE:
    Query Extendability ERD Reference: The Classification Tables below are a visualization of the expandability of the attached queries for the Asset ERD
    Best,
    Fredrick Ndwaru
    Perpetual Ignition
