  • 1.  Fetching Work Order Hierarchies with OSLC
    Posted 02-21-2025 12:26
    I'm used to using OS (SQL) query language, but now I'm forced to use the REST interface and OSLC. I cannot seem to figure out how to fetch a work order hierarchy beginning with one work order number. Using SQL, I would have entered the query "wonum in (select wonum from woancestor where ancestor='mywonum')"
    This seems like a normal thing to do, but my google-fu is weak and I cannot find examples. Anyone else downloading hierarchies?
    Robert Goff
    Xanterra Travel Collection
  • 2.  RE: Fetching Work Order Hierarchies with OSLC
    Best Answer
    Posted 02-21-2025 16:42
    Hi Robert,
    First, you need to create a custom relationship (Let's name it MY_WOANCESTOR, for example) between the WORKORDER object and the WOANCESOTR object using this where clause (wonum =:wonum and siteid=:siteid). This is because there isn't an out-of-the-box one that satisfies your needs.
    Secondly, you need to create a custom object structure with WORKORDER as the main object and WOANCESTOR as its child object and use the MY_WOANCESTOR relationship to link them.
    In MxLoader's where clause uses this query: MY_WOANCESTOR.ANCESTOR="mywonum"
    Hope it helps
    Sadok ABDELLAOUI
    Talan
  • 3.  RE: Fetching Work Order Hierarchies with OSLC
    Posted 02-22-2025 23:42
    Thank you, Sadok, that got me on the right path. I was misled by old habits; the OS service doesn't allow using a related field in the where clause.
    I followed your instructions and was successful. I made a copy of MXAPIWOHIER and added a relationship to WOANCESTOR. (My system already had a relationship called ANCESTORS, but it excluded the top-level work order, ,so I made a new ANCESTOR that didn't.) I specified the query ANCESTOR.ANCESTOR="mywonum" and it fetched the whole hierarchy as desired.
    Then for kicks, I tried the same query with the MXWO object, which has no relationship to WOANCESTOR at all and got the same result. I haven't tested further, but is it possible OSLC will follow relationships that aren't defined in the object structure?
    Robert Goff
