  • 1.  How do I hide step buttons and force a lookup for WO Priority in Technician app?
    Posted 11 days ago
    I'm customizing the Work Order Priority field in the Maximo Mobile Technician app and ran into something I'm not fully understanding.
    For most smart-input fields that use a lookup, Maximo automatically shows the lookup icon (magnifier). But for the Priority field, the default step buttons (numeric increment/decrement) appear instead, and the lookup icon does not show up.
    Here's the scenario:
    • I want to disable the default numeric step buttons for Priority.
    • I want to enable a lookup so the technician selects a priority from a configured lookup definition.
    Even with hide-step-buttons="true" and enable-lookup-buttongroup="true", the priority field still doesn't display the lookup button, unlike similar fields using the same properties.
    Abhishek M R
  • 2.  RE: How do I hide step buttons and force a lookup for WO Priority in Technician app?
    Posted 11 days ago
    The MAF framework doesn't currently support lookups on smart-input when the data type is numeric. I opened an idea for this a while back (Support lookups on | IBM Sustainability Software - Ideas Portal) but I don't believe it has been implemented yet.
    To do a lookup, you need to do something like TECHMOBILE does for worktype out of the box where you use a field control to display the selected value and then add a button that opens the lookup and copies the value and another to clear the value.
  • 3.  RE: How do I hide step buttons and force a lookup for WO Priority in Technician app?
    Posted 7 days ago
    Thanks for the clarification and pointing me in the right direction, it made things much clearer.
    I followed that approach and used a field-control layout with a clear button and lookup trigger. Here's the XML I ended up using :
    <border-layout fill-parent="true" padding="true" width="100%" id="a1_dmrxv">
    <start direction="row" horizontal-overflow="hidden" shrink="0" vertical-align="center" width="60" id="a1_qjy2z">
    <field empty-field-placeholder="Select Priority" required="true" label="Work Priority" swap-position="false" value="{dsWoedit.item.wopriority}" id="a1_drbrr"/>
    </start>
    <middle horizontal-align="end" horizontal-overflow="hidden" id="a1_bgaj9">
    <button hidden="{!dsWoedit.item.wopriority}" icon="Carbon:close--outline" kind="ghost" on-click="clearPriority" on-click-arg="{{'wopriority':''}}" padding="false" id="a1_b67xy"/>
    </middle>
    <end direction="column" horizontal-align="end" vertical-align="center" id="a1_j6v24">
    <button icon="Carbon:chevron--right" kind="ghost" on-click="openPriorityLookup" on-click-arg="{{'page':page,'app':app, 'item':dsWoedit.item}}" padding="false" id="a1_xbv4w"/>
    </end>
    </border-layout>
    Abhishek M R
