  • 1.  How to enable in lookups to Numeric range domain
    Posted 05-16-2024 08:10
    #Assist
    Munikrishnan Raji
    comm-it
  • 2.  RE: How to enable in lookups to Numeric range domain
    Posted 05-16-2024 10:38
    Hi @Munikrishnan Raji!
    Please give me more information about what you need to do so I can help you.
  • 3.  RE: How to enable in lookups to Numeric range domain
    Posted 05-19-2024 20:02
    HI Munikrishnan,
    There has never been a lookup for the numeric range domain as it's a simple validation.  I create a numeric range 0-5 in steps of 1, which means only the values 0,1,2,3,4,5 will be accepted, therefore anything else is invalid.  As you can input any number, there is no option to have a list; otherwise, you'd be using a numeric domain.
    To answer your question, you can't.  You have to think about the intent of the data and the associated validation (if applicable) that you want.  If you are after a picklist, then the numeric domain can be used, if you don't know what the value is or rather to check human error, then a numeric range domain can be used, I call that the fudge or fat finger factor.  A dial reads 1.15 and the human enter 1.13, which is not possible as the gauge being read on reads in steps of 0.05 between 1 and 2.  So, 1.13 could never have been what the technician saw...they need to either correct the entry to 1.15 (actual read) or go back and do the reading again.
    Principal Consultant
    COSOL
    #IBMChampion
  • 4.  RE: How to enable in lookups to Numeric range domain
    Posted 05-19-2024 21:01
    Thank you for your mail. I understand the concept
  • 5.  RE: How to enable in lookups to Numeric range domain
    Posted 05-20-2024 06:50
    Numeric range domain cannot have a lookup. It just validates the number you put ,if in range or not.
    Trisha S
  • 6.  RE: How to enable in lookups to Numeric range domain
    Posted 05-20-2024 07:08
    Thank you for your response. I was find
