  • 1.  how to use mxloader in a environment with AD SSO weblogin using MXLOADER 8.2 next gen
    Posted 11-10-2021 03:46
    Hi SIr,
    THis is really a great tool which saves the days of many project and help lot for maximo data loading in a minute instead of hours
    No words to say simply it is a tool,It is like a box having a to z od data load capablity.
    I like to know one thing which i am struggling for last 2 months
    My environment is a SSO enabled environment
    I cannot use MXLoader after the Security mode enabled in maximo
    reading and checking various blog still unable to use it in an SSO enabled environment
    Please kindly advise ,It will be very helpful for me to learn the particular trick sir
    THanks
    Rajesh Gajendran
    Rajesh Gajendran
  • 2.  RE: how to use mxloader in a environment with AD SSO weblogin using MXLOADER 8.2 next gen
    Posted 05-16-2024 11:18
    Hi Rajesh,
    I'm glad to hear you find the tool helpful! Dealing with SSO-enabled environments can indeed present challenges. Have you tried configuring MXLoader to work with your SSO settings? Sometimes, adjusting authentication parameters or utilizing service accounts can resolve these issues. Additionally, reaching out to your Maximo support team or community forums for specific guidance might provide insights tailored to your setup. Keep exploring solutions; with persistence, you'll find the workaround that fits your needs.
    Best regards,
    Aarohi mitro
    Audre
  • 3.  RE: how to use mxloader in a environment with AD SSO weblogin using MXLOADER 8.2 next gen
    Posted 05-17-2024 15:01
    Can you please better describe your issue?
    Have you tried both Native and LDAP authentication types?
    Can you generate an API key and try API authentication?
    Regards
    Bruno Portaluri (MaximoDev)
