  • 1.  Is it possible to remove the owner and supervisor from Preventive Maintenance records in mass using MxLoader?
    Posted 03-27-2025 12:18
    Hello More Maximo community,
    I am wanting to remove the Owner/Supervisor on multiple Preventive Maintenance records.
    Is it possible to use MxLoader to do so?
    I tried the change option with the fields blank in MxLoader but it did not remove the users.
    I tried the delete option and it deleted the entire PM.
    Thank you in advance,
  • 2.  RE: Is it possible to remove the owner and supervisor from Preventive Maintenance records in mass using MxLoader?
    Posted 03-27-2025 18:03
    Hi Danny
    Yes is the answer.  Please review this article from Bruno. MaximoDev - How to set NULL values with MxLoader
    Principal Consultant
    COSOL
    #IBMChampion
  • 3.  RE: Is it possible to remove the owner and supervisor from Preventive Maintenance records in mass using MxLoader?
    Posted 03-31-2025 12:06
    Thank you @Craig Kokay for the article link.  I appreciate it.
  • 4.  RE: Is it possible to remove the owner and supervisor from Preventive Maintenance records in mass using MxLoader?
    Posted 03-28-2025 08:42
    Use ~NULL~ in the fields you want to delete, then use the Change action.
    Stevie Holloway
    Tufts University
  • 5.  RE: Is it possible to remove the owner and supervisor from Preventive Maintenance records in mass using MxLoader?
    Posted 03-31-2025 12:05
    Thank you @Stevie Holloway.  It worked.
