  • 1.  Issue with Authorized License Usage Not Reflecting for Add-On Module
    Posted 04-18-2025 06:50
    Edited by Hariprasad R 04-18-2025 06:50
    I've added a license for an add-on module with an Authorized license type. I've granted a user full access to a custom application that falls under this add-on, and I've also added the application to the license applications tab for the corresponding license.
    However, I'm still not seeing the "License Used By" table populated for the user, and the "Deployed" count remains at 0. Cron is also running.
    Can someone explain how the license usage works? Is there any additional configuration or action required? I want to ensure that user usage is properly tracked under the authorized license.
    #Security
    Hariprasad R
  • 2.  RE: Issue with Authorized License Usage Not Reflecting for Add-On Module
    Posted 04-21-2025 09:47
    Based on what you're describing, I am assuming you're talking about the 7.6 License Usage Monitor application. There is a process that you need to go through to associate your new/cloned applications with the appropriate license(s) required. We document it in this technote here: Adding custom applications to the License Usage Monitor application
    In MAS, there is no process to associate cloned or custom applications today. In 9.1, IBM is going to handle cloned applications but not custom. The hope is to address custom applications in 9.2.
