  • 1.  Job Plan Sequence 1,6,12 is Throwing Error
    Posted 02-16-2025 11:16
    I'm adding PM records along with Job Plans & their respective sequences with Frequency 1 MONTHS.
    When a PM with Job Plan Sequences 1,3,6,12 is tried via ADDCHANGE, it is properly added in maximo. But when the sequences 1,6,12 are tried, the following error occurs while adding sequence 12:
    "BMXAA8384W - At least one job plan sequence must exist with a sequence of 1"
    Contrary to it, when I see the created PM in Maximo, it has the sequences 1 and 6, and when I add sequence 12 manually, it accepts it properly.
    Therefore, I suspect if there is an issue with MXLOADER behavior with these sequences pattern.
    I'd appreciate if I can have your kind help in this regard that how to upload PMs properly along with these Job Plan sequences.
    Shahid Saeed Khan
    Shahid Saeed Khan
    Oman Airports Management Company
  • 2.  RE: Job Plan Sequence 1,6,12 is Throwing Error
    Posted 03-05-2025 00:33
    Hello Shahid,
    It looks like it is trying to add a new PM record with the sequence 12...
    Do you have another child record in the same load (PMMETER for example)?
    In the "Config" sheet, is the "Split child rows" set to True? If yes, can you try and put it to False.
    Lastly, can you share the file with a data sample?
    Sadok ABDELLAOUI
  • 3.  RE: Job Plan Sequence 1,6,12 is Throwing Error
    Posted 03-06-2025 00:12
      |   view attached
    Hello Sadok,
    Thanks for your reply including the possibilities / reasons of the issue.
    I have verified that the Config sheet is having False for "Split child rows" property. Also, I'm not adding any other child record for the PM.
    For your reference, I'm attaching the MXLoader having sample data which is throwing error and you can try this in your environment.
    Best regards,
    Shahid
    Shahid Saeed Khan
    Attachment(s)
    xlsm
    MxLoader.xlsm   506 KB 1 version
  • 4.  RE: Job Plan Sequence 1,6,12 is Throwing Error
    Best Answer
    Posted 03-07-2025 08:31
    Try keeping the same NEXTDUE date for all.  It looks like you have 4/15/2025 for the sequence 12 line.
    Michael Guns, CRL, CEFP, CMRP
    JFC & Associates
    mguns@jfc-associates.com
  • 5.  RE: Job Plan Sequence 1,6,12 is Throwing Error
    Posted 03-09-2025 01:50
    Thanks a lot for providing the quick resolution! now it worked and PM is properly having all 1, 6, and 12 sequences of Job Plans.
    Best regards,
    Shahid Saeed Khan
  • 6.  RE: Job Plan Sequence 1,6,12 is Throwing Error
    Posted 03-10-2025 09:57
    Glad it helped.
    JFC & Associates
