  • 1.  Labor availability in Assignment Manager
    Posted 09-09-2021 09:46
    I am working with assignment manager and have some labor codes that show negative available hours with no assignments. When I change the calendar associate with the labor code the negative available hours change based on the work hours on the calendar. When the same calendar is applied to other labor codes the available hours are correct. It does not seem to mater what date range I select the pattern remains the same. When I select view assignments the window shows none. It appears that somewhere there are assignments or something affecting the available hours. I have looked at the assignment table and do not see any entries for the affected labor codes. Any suggestions on where to look?
    Kevin Egolf
    TechOps
  • 2.  RE: Labor availability in Assignment Manager
    Posted 09-09-2021 11:35
    Edited by Christopher Winston 09-09-2021 11:36
    Did you check the person record to see of the work dates were modified? Action would be Modify Person Availability.
    this would cause the strange view in Assignment Manager where no work assignments are present:
  • 3.  RE: Labor availability in Assignment Manager
    Posted 09-09-2021 12:10
    I did check that and there are no modifications to the calendar. The negative hours follow the same pattern regardless of the dates selected which seems to eliminate a spot change to the availability. This only seems to affect two of the labor records.
    Kevin Egolf
    kegolf@techopsolutions.net
    Director Asset Management Programs
    TechOp Solutions International
    Cell: 571-344-3221
    EMail logo SDVOSB
  • 4.  RE: Labor availability in Assignment Manager
    Posted 01-31-2025 23:57
    @Kevin Egolf Were you able to find the issue with these LABOR records? I am reviewing similar records in our Maximo instance, and wondering how to track down anomalies on LABOR records that don't behave as expected. Is modify availability on the PERSON record required whenever the calendar is changed?
    Thank you for any help - i recognize this post is a few years old
    Julia Cole
    St. Louis MSD
    Julia Cole
    Metropolitan St.Louis Sewer District
