  • 1.  MAS8 MxLoader 8.3.x
    Posted 09-15-2022 16:17
    Hello all,
    Has anyone run into issues using MxLoader (any 8 version) to load data to MAS8?
    Specifically, I'm using MxLoader to update OOTB Object Structures (MXOPERLOC, MXASSET, MXITEM, etc...) and I continue to get network timeout errors at varying intervals (there has been no pattern that I can see of the timeout, sometimes after a few 100, sometimes after a few 1000)
    I've tried quite a few combinations of the Batch size and Timeout values. Ultimately, I'm still getting timeouts with a Batch Size of 1 and the Max Values for all Timeout fields. I have pared the load files all the way down to required attributes (for MXASSET I've tried loading ASSETNUM and SITEID and still receive timeouts).
    System Details:
    I'd love to hear any insight on potential solutions.
    Matt McGuire
    Aquitas Solutions
  • 2.  RE: MAS8 MxLoader 8.3.x
    Posted 09-16-2022 08:57
    Have you tried using the REST serivce.
    I have had similar problems with random timeouts whilst using the OS service but not REST.
    Not really a solution but it was good enough as a work around.
    Richard White
    Perenco UK
  • 3.  RE: MAS8 MxLoader 8.3.x
    Posted 09-16-2022 09:01
    Hey Richard,
    Good morning and thank you for your response. Yes, I am using REST. To connect to MAS8 you have to use REST/API.
    Matt McGuire
    Aquitas Solutions
