MXLoader - 404 Not Found Error 404: javax.servlet.ServletException: java.io.FileNotFoundException: SRVE0190E: File not found: /api/whoami
  • 1.  MXLoader - 404 Not Found Error 404: javax.servlet.ServletException: java.io.FileNotFoundException: SRVE0190E: File not found: /api/whoami
    Posted 03-03-2023 09:52
    IBM hosted environment and using REST as the Service and API as the Authentication. We've verified with other products the API Key is correct. Anyone see the following and know what to look for in order to resolve:
    Not Found
    Unable to contact Maximo Object Structure service at:
    Check that the server is running and responding on this URL.
    Another environment was restored with this database and connectivity is fine so don't think it is something in the database.
    Matt TRM
    TRM
  • 2.  RE: MXLoader - 404 Not Found Error 404: javax.servlet.ServletException: java.io.FileNotFoundException: SRVE0190E: File not found: /api/whoami
    Posted 03-03-2023 12:57
    Hello - Can you check Web.xml and see OSLC/API Servlet is enabled and not commented out. If it is commented out then uncomment it and redeploy the EAR to see if this solves the issue.
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
