  • 1.  MxLoader Delete Error
    Posted 05-08-2025 08:28
    Edited by Jason Johnson 05-08-2025 08:53
    We're trying to delete duplicate craft entries on some Job Plans. I created an Object Structure for JOBLABOR. MxLoader sees it just fine and can query the objects. However, when I try to Delete, I get the following (unhelpful) error. I've made sure to include the PK. Did I miss something else? Also, we're in a SaaS environment, so our logs aren't readily accessible.
    Jason Johnson
    RSI
  • 2.  RE: MxLoader Delete Error
    Posted 05-09-2025 08:42
    Hi Jason,
    I would first use MxLoader to change the status of the job plan to DRAFT. Then try to delete your crafts. If successful, use the MxLoader again to change the job plan to ACTIVE.
    Stevie Holloway
    Tufts University
  • 3.  RE: MxLoader Delete Error
    Posted 05-12-2025 08:52
    Thank you for the insight. However, even after changing to Draft status, I still get the error.
    Jason Johnson
    RSI
  • 4.  RE: MxLoader Delete Error
    Posted 05-12-2025 09:18
    Edited by Stevie Holloway 05-12-2025 09:18
      |   view attached
    Hi Jason,
    Please see if the attached will work for you. Also, are you trying to use the DELETE action instead of ~NULL~?
    Stevie Holloway
    Tufts University
    Attachment(s)
    xlsm
    JobLabor_MxLoader 8.4.2.xlsm   549 KB 1 version
  • 5.  RE: MxLoader Delete Error
    Posted 05-13-2025 10:15
    Edited by HENRIK SÖDER 05-13-2025 10:17
    Don't think you can update joblabor/jobtasks on JOBPLAN without making a new revision.
    Query the joblan you want to update, make the changes.
    Set revision (pluscrevnum) to next digit (eg 1 -> 2) and load it back into maximo.
    Update status on previous version to "REVISED"
    HENRIK SÖDER
    Quale Consulting AB
