  • 1.  MxLoader - Doclinks
    Posted 03-02-2025 06:55
    Edited by HENRIK SÖDER 03-02-2025 07:23
    I have problem to query/Load doclinks in MAS 9.
    Have done it before in several maximo instances (MX7,6)
    I added doclinks to MXASSET OS and using standard relation (DOCLINKS)
    In MxLoader I use REST/API and in sheet I just tried with minimum info:
    MXASSET ASSET Query
    ASSETNUM SITEID DOCLINKS.DOCUMENT
    Got the asset info but nothing from DOCLINKS/DOCINFO tabels.
    Tried the same in other applications as PM and WO same result.
    Checked everything regarding OS and userrights......
    Created an OS only for doclinks and docinfo and manage to query all needed information but then I miss connection to asset/PM/WO.....
    Anyone knows why e.g. ASSET/DOCLINKS OS not working?
    HENRIK SÖDER
    Quale Consulting AB
  • 2.  RE: MxLoader - Doclinks
    Posted 03-02-2025 10:44
    Created a simple OS just for DOCLINKS found the assetuid and added needed information.
    Got this in result: iface#nodocinfo
    What does this meen?
    HENRIK SÖDER
    Quale Consulting AB
  • 3.  RE: MxLoader - Doclinks
    Posted 13 days ago
    Were you ever able to query DOCLINKS or DOCINFO using an OS where they were the child object?  I am having the same issue.  All OS setup, security and include exclude fields checked.  I am querying PO using a custom OS with DOCLINKS and DOCINFO child objects.  I get PO data, but no data returns for either DOCLINKS or DOCINFO.  Versions:   MAS 9.0.27, MxLoader 8.5.2 (NextGen)
    Christi Eades
    City of Fort Worth
  • 4.  RE: MxLoader - Doclinks
    Posted 03-07-2025 09:42
    So we now manage to load attachments to asset in MAS 9 using MXAPIASSET OS and MxLoader 8.4.2
    But still 2 issues
    1. We don't manage to retrieve any data from doclinks when run query.
    2. When loading a filepath with blanks in filename, the blanks is removed from the path in Maximo making wrong path and the document wont open.
    HENRIK SÖDER
    Quale Consulting AB
  • 5.  RE: MxLoader - Doclinks
    Posted 03-07-2025 12:57
    With file names it seems to be a change so it works with MIF limitations from the 7.5/7.6 time frame:
    Spaces are removed in document name during addition of attachment When you attempt to add an attachment to any object (work order, asset, etc), if the document name you are adding contains spaces, those spaces are removed once the document is added.
    Sun
Watch Episode 6
