  • 1.  MXLoader Update Row Limitation
    Posted 08-13-2024 16:28
    Hi,  Our Maximo Admins have run into issues updating a field for a table with 250,000+ rows.  Is there something in MXLoader configuration to accommodate large number of records to update?  I have "heard" there is.
    Claudia Cox
    Claudia Cox
    City of Henderson
  • 2.  RE: MXLoader Update Row Limitation
    Posted 08-16-2024 16:29
    Hi @Claudia Cox
    I see 2 parameters that are:
    Maximum objects: Maximum number of rows that can be retrieved with a Query request. Set to 0 to disable (not recommended).
    Batch size: If you want to split the updates that MxLoader sends to the server you can set this value to 1 or more. Set it to 0 to disable (default). This setting is used only for Sync and Delete operations.
    Since there are 250,000, you could create batches of 10,000 each (25 batches).
