  • 1.  Object variable or With block variable not set
    Posted 01-21-2022 11:40
    Has anyone been getting the error:
    Object variable or With block variable not set?
    I am getting it when I try to just use a query to select assets and items, and also when I try to add/change.
    I'm using MxLoader 8.3 and my maximo environment is Maximo 7.6.1.2 IFIX 12.
    Any suggestions would be appricated.
    Nate Hoffman
    Nate Hoffman
    Projetech
  • 2.  RE: Object variable or With block variable not set
    Posted 02-02-2022 04:00
    I wanted to use Mxloader 8.3.1. I'm using Mxloader 6.2. I don't get this error. I also get this error with Mxloader 8.3.1.
    Aliriza Canakci
    Is Merkezleri Yönetim ve İşletim A.S
  • 3.  RE: Object variable or With block variable not set
    Posted 04-10-2023 23:44
    Did anyone come up with a solution here?
  • 4.  RE: Object variable or With block variable not set
    Posted 04-11-2023 09:37
    The issue ended up being that one of the fields I was using was not in the object structure I was using.  I added the field to my object structure, and the issue resolved itself.
    Nate Hoffman
  • 5.  RE: Object variable or With block variable not set
    Posted 03-26-2025 18:34
    I was also getting this message, with MxLoader 8.4.2. I was updating the EXTERNALREFID on Locations and the field was in the Object Structure (MHOPERLOC).  It turned out, I was missing the "s" on the Maximo HTTPS URL on my MxLoader Config tab.  I was able to query the Object structure with the HTTP (no s) URL.
    Randi Wagner
    Maven Asset Management
