  • 1.  PRLINE and Work order
    Posted 01-19-2023 12:34
    Hello Everyone,
    For a PR there are multiple PRLINE's attached to it and each PRLINE has Work orders attached.
    Suppose if the different PRLINE's has the same Work orders attached then we need to sum up the Line Cost of PRLINE for which the Work orders are same. And if the sum up of Line cost of PRLINE is greater then the Budget remaining of Workorder, it should throw an error.
    How can we write this code through Automation script? Can anyone please help on this requirement?
    Thanks in Advance.
    #Procurement
    Sowndarya Seshadri
    TCS
  • 2.  RE: PRLINE and Work order
    Posted 01-19-2023 20:41
    Can anyone help on this requirement
    Sowndarya Seshadri
    Accenture
  • 3.  RE: PRLINE and Work order
    Posted 01-24-2023 00:17
    Hi - Question when you are asking to consider WO Budget, where is the Budget located on Work Order - Is this in Budget Monitoring Application, or is a custom field added on WO?
    You need to work on MboSet to get this done. Refer methods you can available here-
    https://bportaluri.com/wp-content/MaximoJavaDocs76/psdi/mbo/MboSet.html
    Sedin Technologies
    #IBM Champion 2022
