  • 1.  Search workorder records not inserted in woancestor through query
    Posted 11-01-2022 11:54
    Edited by Joe Kelley 09-07-2023 17:34
    Does anyone have query to find the missing records of woancestor table that are present in workorder but its entry is not made woancestor table by system.
    Ramesh Kumar
    student
  • 2.  RE: Search workorder records not inserted in woancestor through query
    Posted 11-21-2022 10:29
    SELECT wonum
    FROM workorder
    WHERE wonum NOT IN (SELECT wonum FROM woancestor)​
    Is that what you are asking for?
  • 3.  RE: Search workorder records not inserted in woancestor through query
    Posted 05-10-2023 20:06
    Hi Travis,
    There is a flaw in your query.  The WORKORDER object exists at the site level.  So, the work order number could be repeated in each site.  You need to involve the SITEID.  I generally find an EXISTS or in this case, a NOT EXISTS statement is much less costly and is faster, but just crafting the SQL statement to involve the fields involved in an index will also be faster.  I've included a version here.
    SELECT wonum
    FROM WORKORDER w
    WHERE NOT EXISTS
    (SELECT 1 FROM WOANCESTOR w2
    WHERE w2.wonum = w.WONUM
    AND w2.SITEID = w.SITEID );
    ISW
    Maximo Practice Manager
    eMail: ckokay@isw.net.au
    Phone: +61-411-682-040
    #IBMChampion2023
  • 4.  RE: Search workorder records not inserted in woancestor through query
    Posted 07-11-2023 19:56
    I believe Integrity Checker will also report these.  It might be a good idea to run this in case there are other issues lurking.  I don't recall if it lists the workorders, but you can see the SQL used in the log. 😊
    Steven Hauptman
