  • 1.  Searching for inventory that has no usage but has been in the storeroom for more than 7 years.
    Posted 10-29-2024 16:06
    I am trying to create a query within Maximo for a storeroom attendant to query items in their storeroom that has had no issues for the past 7 years, has been in the storeroom for over 7 years and has no open PO's or PR's.  We will use this query to determine whether to obsolete the inventory record from the storeroom.  I have a couple queries that I have tried to modify and/or combine but I can't make any of them work together.  I would appreciate any help.
    This query gives me all items without an open PO
    status = 'ACTIVE' and not exists (select 1 from poline pol where inventory.siteid = pol.tositeid and inventory.location = pol.storeloc and inventory.itemsetid = pol.itemsetid and inventory.itemnum = pol.itemnum   and pol.receiptscomplete = 0 and pol.linetype = 'ITEM'  and exists (select 1 from po where ponum=pol.ponum and revisionnum=pol.revisionnum and siteid=pol.siteid and status in ('APPR', 'CONF') and revisionnum = (select max(revisionnum) from po por where por.ponum=po.ponum and por.siteid = po.siteid) ) )
    This query gives me all items with any transactions in the INVTRANS table that are dated within the last month but we need inventory with INSERTTYPE = INSERTITEM and  INVTRANS.TRANSDATE > 7 YEARS
    siteid = (select defsite from maxuser where userid = :&USERNAME& ) and (exists (select 1 from dbo.invtrans where (datepart(m, transdate) = datepart(m, dateadd(m, -1, getdate())) and datepart(yy, transdate) = datepart(yy, dateadd(m, -1, getdate()))) and (itemnum = inventory.itemnum and storeloc = inventory.location and siteid=inventory.siteid)))
    And I want to combine these 2 queries into one.  Can anyone help me with this?
    Teresa Allen
    GAF
  • 2.  RE: Searching for inventory that has no usage but has been in the storeroom for more than 7 years.
    Posted 10-30-2024 08:28
    Edited by Stevie Holloway 10-30-2024 08:31
    Hi Teresa,
    Please try this.
    status = 'ACTIVE'
        AND siteid = (SELECT defsite FROM maxuser WHERE userid = :&USERNAME&)
        AND NOT EXISTS (
            SELECT 1
            FROM poline pol
            WHERE inventory.siteid = pol.tositeid
                AND inventory.location = pol.storeloc
                AND inventory.itemsetid = pol.itemsetid
                AND inventory.itemnum = pol.itemnum
                AND pol.receiptscomplete = 0
                AND pol.linetype = 'ITEM'
                AND EXISTS (
                    SELECT 1
                    FROM po
                    WHERE ponum = pol.ponum
                        AND revisionnum = pol.revisionnum
                        AND siteid = pol.siteid
                        AND status IN ('APPR', 'CONF')
                        AND revisionnum = (
                            SELECT MAX(revisionnum)
                            FROM po por
                            WHERE por.ponum = po.ponum
                                AND por.siteid = po.siteid
        AND NOT EXISTS (
            SELECT 1
            FROM prline pr
            WHERE inventory.itemnum = pr.itemnum
                AND inventory.itemsetid = pr.itemsetid
                AND inventory.location = pr.storeloc
                AND pr.siteid = inventory.siteid
                AND EXISTS (
                    SELECT 1
                    FROM pr
                    WHERE prnum = pr.prnum
                        AND pr.siteid = pr.siteid
                        AND status IN ('APPR', 'PEND')
        AND NOT EXISTS (
            SELECT 1
            FROM dbo.invtrans
            WHERE inventory.itemnum = invtrans.itemnum
                AND inventory.location = invtrans.storeloc
                AND inventory.siteid = invtrans.siteid
                AND invtrans.transdate >= DATEADD(year, -7, GETDATE())
        AND EXISTS (
            SELECT 1
            FROM dbo.invtrans
                AND invtrans.transdate <= DATEADD(year, -7, GETDATE())
    Stevie Holloway
    Tufts University
  • 3.  RE: Searching for inventory that has no usage but has been in the storeroom for more than 7 years.
    Posted 02-26-2025 11:25
    Thanks for this response, being new to this site I didn't realize anyone responded. I tried your query without luck.  Is this SQL server?
    Teresa Allen
    GAF
  • 4.  RE: Searching for inventory that has no usage but has been in the storeroom for more than 7 years.
    Posted 02-27-2025 19:41
    Hi Teresa,
    INVTRANS table records inventory adjustment transactions (balance, cost and so on), but not issues and returns to store. These are in MATUSETRANS. Also, INVENTORY.LASTISSUEDATE should tell you when an Item was last issued. I'd suggest something along these lines (remove comments for use in Where Clause):
    siteid = (SELECT defsite FROM dbo.maxuser WHERE userid = :&USERNAME&)
    and status        = 'ACTIVE'
    and location      = 'MYSTOREROOM'
    and lastissuedate < current_date - 7 YEARS       -- (DB2)INVENTORY keeps Last Issued date here
    --   and lastissuedate < DATEADD(year, -7, GETDATE())       -- for SQL Server
    and exists (                                     -- Has a current balance
    select 1 from dbo.invbalances
    where itemnum = inventory.itemnum
    and siteid    = inventory.siteid
    and location  = inventory.location
    and itemsetid = inventory.itemsetid
    and curbal    > 0
    and not exists (                                 -- Not on any open PO (could extend Status selection for WAPPR, PNDREV, INPRG?)
        select 1 from dbo.poline l
        inner join dbo.po on
            po.ponum           = l.ponum
            and po.revisionnum = l.revisionnum
            and po.siteid      = l.siteid
            and po.status in (select value from synonymdomain where domainid = 'POSTATUS' and maxvalue in ('APPR','HOLD'))
        where
        l.itemnum      = inventory.itemnum
        and l.siteid   = inventory.siteid
        and l.storeloc = inventory.location
    and not exists (                                 -- Not on any open PR
        select 1 from dbo.prline l
        inner join dbo.pr on
            pr.prnum      = l.prnum
            and pr.siteid = l.siteid
            and pr.status in (select value from synonymdomain where domainid = 'PRSTATUS' and maxvalue in ('APPR'))
        where
    order by siteid, location, itemnum
    Good luck
    Steve Bruce
  • 5.  RE: Searching for inventory that has no usage but has been in the storeroom for more than 7 years.
    Posted 02-28-2025 07:46
    Hi Steve,
    I tried this out as SQL Server, and it worked.
    Stevie Holloway
    Tufts University
