  • 1.  SENDERSYSID Field
    Posted 10-28-2025 12:36
    Does anyone know if there are any business rules associated with the SERNDERSYSID filed in the LABTRANS table?
    Jeffery Murray
    JJWWS
  • 2.  RE: SENDERSYSID Field
    Posted 10-29-2025 11:01
    Detailed Explanation:
    • Purpose of SENDERSYSID:
      • It is a metadata field used in Maximo's integration framework (MIF).
      • The field stores the identifier of the external system that sent the transaction into Maximo.
      • This helps Maximo distinguish whether a record originated internally (via Maximo UI or automation scripts) or externally (via an integration channel).
    • Business Rules (or lack thereof):
      • There are no functional business rules in Maximo core applications (like Labor Reporting, Work Order Actuals, or Time Reporting) that depend on SENDERSYSID.
      • The field is not validated against other Maximo objects (e.g., it doesn't enforce referential integrity).
      • It is not used in cost calculations, approvals, or validations for labor transactions.
      • Its main role is traceability in integration scenarios-useful for troubleshooting and auditing.
    • When it matters:
      • In multi-system environments (e.g., Maximo integrated with ERP, HR, or payroll systems), SENDERSYSID can be used to:
        • Identify the origin of a LABTRANS record.
        • Prevent duplicate processing of inbound transactions.
        • Support reconciliation between Maximo and external systems.
      • In standalone Maximo environments, the field is usually empty or ignored.
    • Customization potential:
    • Some organizations create automation scripts or escalation rules that leverage SENDERSYSID to:
      • Filter out records from specific systems.
      • Apply conditional logic (e.g., "if record came from SAP, don't allow edits in Maximo").
    • These are custom rules, not out-of-the-box Maximo behavior.
    ✅ In summary: Out-of-the-box Maximo does not enforce business rules on the SENDERSYSID field in LABTRANS. It is an integration tracking field, and any business logic around it would be custom-built depending on your integration strategy.
    Johan Serfontein
    Profound Focus
  • 3.  RE: SENDERSYSID Field
    Posted 10-30-2025 09:24
    Johuan,
    Thank you for the detailed reply. This was exactly what I needed!
    V/r
    Jeffery Murray
    JJWWS
