  • 1.  Updating Inventory using MxLoader with physical counts
    Posted 06-05-2024 02:39
    Our organization is getting ready to do physical inventory counts and wants to us MxLoader to update Maximo.  We are not sure if this is simply updating the amounts or do we need to make other transactions to capture shrinkage or any other data?
    Any advice you may have would be greatly appreciated.
    Carlton Gillespie
    City Of Cincinnati
  • 2.  RE: Updating Inventory using MxLoader with physical counts
    Posted 06-05-2024 09:40
    After the physical count is uploaded and any audit steps completed, each item must be reconciled. This can be done one at a time, or in bulk from the Inventory list tab.
    Robert Goff
    Xanterra Travel Collection
  • 3.  RE: Updating Inventory using MxLoader with physical counts
    Posted 07-01-2024 14:19
    How are you loading the physical count?  I'm trying to load via MxLoader and I've getting an error: Bad Request
    Error 400: BMXAA1359E - The inventory balance cannot be created because the inventory does not exist.
    Carlton Gillespie
    City Of Cincinnati
  • 4.  RE: Updating Inventory using MxLoader with physical counts
    Posted 08-26-2025 14:58
    Just to confirm, you are performing a physical count and not a current balance adjustment?
    The most common issue I run into is blank bins. (you'd have to insert ~NULL~) if you're using the Object Structure (OS) method instead of the new REST API.
    https://bportaluri.com/2020/04/set-null-empty-values-with-mxloader.html
    Otherwise, it could simply be that you're going to the wrong storeroom, or the bin itself has a space in it or some other valid value for BIN that is not apparent.
    sun kim
  • 5.  RE: Updating Inventory using MxLoader with physical counts
    Posted 01-31-2026 11:22
    This is an older post from 2024, but our organization currently reconciles inventory counts manually in MXLoader as opposed to Count Books while we work out some limitations with Count Books, but it comes with its own shortfalls.  If you are still needing some information for this, feel free to message me.
    Charli Sanders
    Durham School Services
