The the print function writes to the system standard out, which generally will write either to the SystemOut.log (Maximo 7.6) or the console.log / messages.log in MAS. In a clustered environment you will also need to know which JVM (Maximo 7.6) or pod (MAS) you are connected to so you can find the appropriate log.
In most automation script executions there is an implement variable called "service" that is the instance of the com.ibm.tivoli.maximo.script.ScriptService class, which has functions log_[level], for example service.log_info("your message"). This will log to the maximo.script logger as defined in the Maximo logging application and give you a lot more control over where the log is written and of course the granularity of the logging.
You can also look at our VS Code extension, which provides the ability to stream the Maximo log to your VS Code environment and is handy for development purposes.
Jason
