Is it possible to interact with workflow input nodes without a session (requests made using API key)? I have no issues initiating workflow or handling task nodes without input options when I make requests using the API key however when I try to POST an input node option to the location URL (redirect) provided by a task node I get an error: oslc#invlaidwfinstid (yes, invlaid not invalid).
If I start a session and make the requests (i.e. log in with basic auth, choose a task route, POST input option to location in previous response, etc.) it works fine.
I'm using Postman and cookies are being shared from request to request.
Which version of Maximo are you using?
What is the context you are using /maximo or /api?
Join CommunityInvite ColleaguesLearn MoreGet Started on MORE
About UsTerms of Use
