Hi Fitzroy!
These dialogs are likely stored in the LIBRARY.XML file, accessible by Application Designer > Select Action > Export System XML > [select LIBRARY].
You can then search through the XML for id="owner".
You then have two options:
- You can directly edit the XML for the dialog and re-import LIBRARY.XML to impose the changes
- You can also export SR and copy / paste the "owner" dialog XML into the SR application and re-import that (Maximo always looks first to the on-screen application definition for dialogs and only refers to LIBRARY.XML if the referenced dialog isn't defined at the application level). After re-importing, the dialog (a copy) would be accessible / editable from w/in Application Designer in the SR screen definition.
Cheers,
Jade
