 MAS 9 MANAGE INSPECTION FORMS
  • Assets
  • Maximo Visual Inspection
  • Work Centers
  • Work Management
DESIREE HARSHMAN's profile image
DESIREE HARSHMAN posted 08-25-2025 08:55
We recently migrated over to MAS 9.  I am trying to get the manage inspection forms application.   I have the inspection form tab under role based but am unable to create or make any changes to the existing forms.  Is this an add- on maybe we don't have yet. Can someone please assist me.  TIA!
The new UI is a little bit confusing on how to modify.
Assuming you do not have a pending revision already, you first need to create a revision. You can do this by hovering your mouse over on the far right of the record, clicking the triple dots, and choosing Revision History.
Then at the top right you can click Create Revision
Similarly, when you have a pending revision or draft record, click the "Revision History" and then on the far right of the revision you can modify hover your mouse and open the triple dot menu. You can choose Edit (to add/remove/modify questions), Conditions to add conditions to questions, or Form Settings to do things like associate an automation script action.
DESIREE HARSHMAN
Thank you that is helpful! I will try that out.
