Hi Abhirami,
I would like to add few more areas to check
- Go to Organizations-->PM Options--> and make sure that automatic PM work order generation check box is enabled for the site for which you want to generate PM's.
- Make sure to enable the history check box against the cron instance and check whether the Cron action is happening.
- Check instance property values for mxe.crontask.donotrun and mxe.crontask.dorun to make sure that this configuration is not affecting the cron task run.
- Check the security privileges for the RUNASUSER for the crontask instance and make sure SITEAUTH's are configured correctly.
Nidhil Chathoth
ECCS Ltd
